Has anyone accessed the 3rd brake light wiring? Need info/details on how to get to wiring for the...
unit. Does the brake light assembly remove without taking off the entire plastic cover that surrounds the inside of the rear window? or is there an easier way? Another little project and just want some info...this isn't too far OT is it ;-)
Roadsters anyway are tough
My dad's car had the light fail early on (I think it was a lose connection) and they ended up taking apart a fair amount of the inside of the car to get to it... Don't know anything about coupes though - knowing Audi they would make it hard just because
good luck
good luck
If it's anything like the roadster, you need to lift up, and remove the plastic cover at the back...
this gives you access to the mounting screws, and to the cable.
You can *carefully* lift up the back edge, and then the cover releases from these pins here.
<img src="http://people.mn.mediaone.net/jbipes/jpgs/brakelightcover.jpg">
Once you get the cover off. (Looks like this)
<img src="http://people.mn.mediaone.net/jbipes/jpgs/redlens.jpg">
You will see the T-25's and you can remove it. I had to go into the trunk area to get at the connector.
<img src="http://people.mn.mediaone.net/jbipes/jpgs/removed.jpg">
On the roadster, this whole red plastic piece is ultrasonically welded shut.
*NO WAY* will it come apart, save for destroying the unit.
I was going to attempt this, with a small Dremel cutting wheel, but I decided against it.
TwinTurboTerror
03-06-2005 02:31 PM
BluDemon
06-29-2002 03:39 PM
KenK in TX
02-07-2001 11:55 AM
WECoyote-SuperGenius
11-02-2000 08:57 AM
