Has anyone ever tried this product....I'm running out of the Porsche product and thought I might...
<center><img src="http://pictureposter.audiworld.com/9906/autofanatics1_1669_6700202_copy.jpg"></center><p>Wolfsteins Pro Series bring you the lastest in top care.
RAGGTOPP Cleaner and RAGGTOPP Protectant have been thoroughly tested and endorsed by HAARTZ, the world's leading manufacturer of convertible topping fabric since 1920s. HAARTZ is the designated supplier of convertible topping fabric for virtually every U.S. automaker and most European manufacturers, and is the world's only manufacturer of both PVC and cloth combined automobile and sport utility topping. RAGGTOPP Protectant was specially developed to protect and maintain fabric convertible tops from harmful elements. The number one factor in deteriorating these treasured, and expensive tops, is acid rain. When you add the damage caused by U.V. rays, smog, tree sap, bird droppings, tar dirt, grease and grit you are fighting a difficult battle against the elements that contribute to the weakening and failure of convertible tops. RAGGTOPP combats these assaults with ease and determination. The added plus to this product is in how easy it is to apply. No more masking off the paint work and plastic window. This product will not damage either. It just wipes off. As a matter of fact, this product will actually clear up and help prevent water spotting on your plastic windows and works wonders as a protectant on your carpet floor mats. No kidding! Just started using this on the tonneau cover for my truck bed and its terrific! This is really easy to use and produces great results. It is best applied in 2-3 light coats with drying time in between. What's great is that you are encouraged to apply it in sunshine so it will help the drying cycle. When using RAGGTOPP on vinyl, here's a trick: spray it on and use a towel or sponge to spread it around for full coverage. Let it dry and repeat 3 times. On vinyl this ensures better coverage. The results are spectacular. Anything this easy should be kept a secret...except for AutoFanatics. We've been using this on our truck tonneau covers too! Out performs the rest. RAGGTOPP is tops in its field for both protection and ease of application! My favorite! - Fluorocarbon Re-Water Repelling System - Will Not Harm Paint or Glass Surfaces Helps New Convertible Tops Maintain Their Appearance Longer - Renews and Extends the Life of Older Tops - UV Protection with UV Stabilizers 14oz Ozone friendly aerosol. No silicone, freon or CFC's. |
I've used Porsche's Tequipment too. It works well, but I don't like taping off the windows and paint
Here's the results
Clean top (mmmm)
<img src="http://images.fotki.com/v1/photos/1/11117/44170/cleantop2-or.jpg"> I use this and I don't tape the paintwork (it's pretty well protected with Z!). Seriously though, it goes on with ease and there is never much spill onto the paint. When and if this happens I just wipe it down immediatly and it's all ok. This is using the RagTop cleaner and Protectant, ask Gina how well it beads! :) Enjoy |
Don't use tape, just newspaper under the top and in the windows. It's relatively painless that way.
That's one reason I'm considering the change....But, I like the write up it received....
That's a great tip....!
