HELP .. !!
Old Sep 12, 2005 | 05:15 PM
TTMeUp's Avatar
New Member
Default HELP .. !!
I just dissconected the bat for about 15 min s and then re-connected and did a TBA ..
I went for a quick drive down the street whilest reading block 32 .. and 0.0 s ..
Went back into engine and no fault codes but readiness had the following ..
<img src="http://pictureposter.audiworld.com/93045/1st.jpg">
And the OBD readiness for the O2 showed.
<img src="http://pictureposter.audiworld.com/93045/2nd.jpg">
Anyone have an idea, or is it just learning .. ??
Dont know if the ECu reset as the radio did not go into safe.
Thanks
Old Sep 12, 2005 | 05:19 PM
msauve's Avatar
Looks normal.
Old Sep 12, 2005 | 05:21 PM
TTMeUp's Avatar
New Member
for wat ?, just doing a tba ?
Old Sep 12, 2005 | 05:23 PM
TTinCT's Avatar
Rest In Peace
Default the key word in all of those tests....Incomplete..;-) >>>
more than likely...the ecu reset...
Old Sep 12, 2005 | 05:25 PM
JohnLZ7W's Avatar
Default for disconnecting the battery
the readiness codes get set to fail/incomplete if you pull the battery or even just clear faults using a VAG. They'll go back to passed after a few restarts.
Ben3.2TT@BC's Avatar
Member
Default Drive around a couple of days and then check again. Make sure you include highway driving too.
It was the same for my B5 A4 1.8T.
Old Sep 12, 2005 | 05:35 PM
TTMeUp's Avatar
New Member
Soz guy's .. just an old fart getting into a panic .. Thx for calming the nerves.
Old Sep 12, 2005 | 05:38 PM
TTMeUp's Avatar
New Member
1st time of doing this .. I thought I had blown the O2 sensor . 8O
 Michael S. Palmer
Old Sep 12, 2005 | 05:42 PM
TTMeUp's Avatar
New Member
I will. Thx I commute from NJ to Philly, so It shouldnt take long
Old Sep 13, 2005 | 01:47 AM
LiTTespeed's Avatar
Default Interesting - just had somethign similar happen and of course I failed NJ Inspection due to it
think I also disconnected the battery and it took quite awhile of daily commuting (120 miles per day) for it to reset itself. Not necessarily convinced in my case that it isn't some other odd gremlin but I had the exact pass, fail, incomplete IIRC that you saw.
