Help with changing the OEM xenon low lights
After I remove the plastic cover from the back of the Low and High lights, I unscrew the
retraining (red)piece that hold that bulb in, but I cant get the OEM bulb from comming out, its like stuck. Do I have to pull it hard (tried already), twist it counterclockwise or clockwise? Thanks!! |
After removing the retaining ring, the xenon bulbs should be easily removed.
Just pull them straight out.
I tried pulling them hard, they are just stuck on there.
