Help with codes
Old Mar 17, 2006 | 04:02 PM
  #11
Butterstt's Avatar
New Member
Default Re: Help with codes
Yeah car information would help wouldnt it...
2001 TT 180
FORGE Intake
FMIC
FORGE DV
Custom Down pipe
49k on the clock
Stock ECU
Old Mar 17, 2006 | 04:33 PM
  #12
TT_Nuge's Avatar
Senior Member
Default And what are the symptoms you are feeling while in the car?
Tell us more about the problems and why you went searching for the codes.
Old Mar 17, 2006 | 06:08 PM
  #13
Blue TTop's Avatar
Agreed...........
Old Mar 17, 2006 | 06:18 PM
  #14
Butterstt's Avatar
New Member
Default Re: And what are the symptoms you are feeling while in the car?
Well heres what is going on, in the morning when I first start the car it will misfire a lot until the car goes into closed loop. Once in closed loop the car will run fine after driving the car for 20 to 30 min it begins to have a slight miss between 2500-3500 and will not make boost or accelerate. If I let off the gas the gauge boost shows zero vacuum, if I give it gas the RPM will slow start to come up but only make 2-4 lbs of boost. This will happen a few times then the car will take off like a rocket and run fine after this happens. The odd thing is the CEL only comes on every once in awhile. So far I have checked the vacuum lines but none are broken or loose. I thought it was bad gas but its been happening a lot more lately. Also noticed that ther is a small amount of oil coming out of the dv/bov I think the pcv is failing but I am not sure about that. I change the oil every 2500 mile like clock work and it only gets 91 or 93 octane. I am going to pull the plugs and check them, is there anything else I should look at?
Old Mar 18, 2006 | 05:58 AM
  #15
Straz85's Avatar
Default I would guess it's 1 of 3 things, first thing I would try is cleaning out your
throttle body with throttle body cleaner (not carbeurator cleaner), second could be your coilpacks, and there is a small chance it could be your MAF sensor. I say to try the throttle body cleaner first because it's cheapest, but if it's most likely your coilpacks.
Old Mar 18, 2006 | 02:15 PM
  #16
Butterstt's Avatar
New Member
Ok here is what I found, first was a broken vacuum line to the Secondary Air Injection Solenoid Valve, so I replaced it. Second I pulled the plugs they looked ok but will need to be replaced soon, I also found carbon tracks in all of the coil packs, so I think I will have to replace those too. I cleaned the MAF (I found a feather traped between the screens, so I pull that out. I cleared the codes in the car and drove it only thing that came up was the Secondary Air Injection Solenoid Valve code, so I think I have to replace that before I do anything else. What do you guys think?
llonman
11
May 9, 2010 05:02 AM
llonman
Mar 9, 2010 05:28 AM
saquib
Oct 29, 2009 06:10 PM
dioxin
Nov 18, 2005 06:58 PM
faust92
May 10, 2004 09:16 AM
