Help needed! Antifreeze question
Replaced the coolant sensor but forgot to tighten the filler cap before I pulled the sensor and lost a lot of antifreeze, including draining the reservoir. No VW/Audi dealers open today. Local parts shop says Preston's orange color is equivalent but I also see that Prestone makes a pre-mixed clear product that claims is good for ANY make and model car. The alternative is to refill with water and then drain and refill tomorrow when I can get to Audi/VW product. Advice please!
Answer: Pentosin is equivalent. Stay clear of the Prestone stuff
Pentosin G12 is listed on several audi/VW performance parts sites. Bracketracer gives it a thumbs up too.
Good luck finding that on a Sunday.
I repeat... fill with distilled water. Then drain some out tomorrow, and pour in some G12. If you keep track of how much you're adding / removing, you can do some simple calculations to return it to an approximate 50/50 mix.
Cruzad3r
09-10-2008 01:58 PM
siberian
12-18-2003 07:22 AM
