HELP:Still smell transmission oil
Old 11-03-2008, 07:22 PM
New Member
johnson_7773's Avatar
Default HELP:Still smell transmission oil
I changed my transmission oil yesterday, but when I drove on freeway I smell the transmission oil for about 5 seconds and it is gone. But this morning when I drove on freeway, I smell it about 5 seconds again, I wonder what happend?
I pumped 3qts into transmission but the oil did not spill out. When I fill the oil, I drove my car on the ramp, so my car car wasn't leveled. Is that the problem caused the smell?
I leveled my car today and open the fill hole, about 1/5 qt came out and I cleaned up the oil around fill hole and go for a test drive, it was fine.
But tonight I test drive again, I still smell the transmission oil, I wonder why?
Can anyone tell me where is the vent hole, I'm guessing there is still some oil cause the smell.
Anyone overfilled transmission oil before? please give me some advice.
Old 11-04-2008, 04:28 AM
Senior Member
OldSchool AG's Avatar
i think it's just going to take a while to burn it all off. give it a few more drives
Old 11-04-2008, 06:28 AM
Russ Scott's Avatar
Default did you remove both drain plugs? edited
both the trans and bevel box?
assuming quattro, 3 qts won't over fill it, if it was completely drained
edit: the capacity chart says 2.7 qts, so 3 qts <i>is</i> over filled.
fwiw, I drain mine at 50k mile intervals and have put the full 3 qts in... this way for 100k+ with no problems
Old 11-04-2008, 10:41 AM
New Member
Yes, I drained both the trans and bevel box.
Old 11-04-2008, 10:43 AM
New Member
When I drive on freeway this morning, I can still smell it, but it is less strong than yesterday.
Old 11-04-2008, 10:44 AM
New Member
Anyone know is there a vent hole on the transmission? Where is it?
Old 11-04-2008, 11:46 AM
New Member
Default I changed the rear differential oil also, is that possible the smell from there?
I pumped 1qt into the rear differential.
am_ver
09-12-2011 10:36 AM
johnson_7773
11-03-2008 01:05 PM
N X B 3
04-12-2005 12:24 PM
AW #29529
10-05-2002 10:18 PM
Kep
07-14-2001 11:11 AM
Quick Reply: HELP:Still smell transmission oil
