How can I reprogram the FOB for my 2006 Audi TT Quatto?
There is more than one procedure for re syncing a key fob. Read through this thread.
https://www.audiworld.com/forums/tt-...ement-1954050/
For the radio, you will need the safe code. It should be recorded in your owners manual.
With the code--
Audi Concert Radio
Radio is on and appears in “SAFE” mode
Simultaneously press the FM 2 and RDS buttons, holding them down, until “1000” lights up. Release the buttons. (If you continue to hold the button down or press the buttons again this will make the radio think your radio code is 1000, so don’t do that)
Use the station buttons 1 through 4 to input the radio code. Press button one repeatedly until you arrive to the correct number (once would be one, twice would be two and so on.)
Once you have entered the correct code in the display press the FM 2 and RDS simultaneously again, holding down until SAFE is displayed.
The radio should be working when you release.
With the code--
Audi Concert Radio
furiousgeorge
17
09-01-2006 10:34 AM
