How do the LLTek taillights stay on? and are they removable?
TT Doug and MichaelTT have had some problems with their light covers.
They both have had some "bubbling" trouble with them. I know MichaelTT had his replaced. My husband (Doug) hasn't replaced his yet. From what I understand, they do come off, with little or no difficulty. Putting them on is another story. Not difficult, per se, just time consuming. They come with a very thick goop, but I believe both Michael and Doug used something different. Doug used silicon caulk. Hope this helps.
The goop that comes with the covers is the same as that used to hold the badges >>
on and although it's a pain to work with (very sticky stuff) it works. I've had my covers on for 2 years in New England weather with no troubles at all. Removal might be a tedious process but why would you want to? Buy new lense covers.
Picking up from what tiTTilllating said>>>>
Yes I replaced my after problem with first set but Lltek now sends covers with different adhesive...now install is very easy...apply adhesive carefully on back side of cover, position on tail light lens, fine position a bit if needed, press into place, and then every five minutes of so for next 30 minutes evenly press over entire cover..thats it. Yes can be removed but will destroy cover but will not harm lens...takes a little bit of 'ebow grease'/effort to get all the adhesive off the lens.
onepoint8t
10-16-2002 06:27 PM
Badness
01-10-2002 05:57 PM
Tom Halter
05-12-1999 11:08 AM
