How long does it usually take before lowering springs and shocks settle?
I'd get it done twice.....
reason being... if the alignment is way off, 300-500 miles is more than enough to get a wear pattern started on the tires... and from my experience, once that pattern is started, it doesn't seem to matter if you correct the alignment!
alignments are pretty cheap compared to tires!!!
have it done, and then in about 500 miles, have it rechecked and adjust if needed.
not really.....
It's not that you get sudden extreme tire wear... but it starts a wear pattern. And for some odd reason the tire will continue to wear in that pattern even after the alignment is fixed.
I've had this happen more than a few times!!! Especially if the toe is off....
Maybe my car was just weird though.. I'm just speaking from my experience.
