How low can I go before I need a kmac kit?
you may not need kmacs or camber arms with UUC's...as a matter of my impression the rears tend to...
...wear on the outside because of the cornering forces of most of our driving....but if you want superior handling without the camber wear...I have found that -1.6- to -1.8 degrees is nearly perfect for street and -2.3 to - 2.5 for track on my setup....the geometry of the TT suspension will increase toe-in with more negative camber...if I had to guess given the 3/4" typ. lowering with uuc springs I would speculate that you are at -1.7 to -1.8...so that may not be an issue...with lowering beyond 1" kmacs are needed and if preferred camber Arms...I llike terry's arms...
Ditto on the -1.6. That appears to be a nice, ....>>
moderately aggressive street setting. With a 1 inch drop, I needed Kmac's to dial this in. Do uppers and lowers of you want easy toe adjustability.
A6sport
05-20-2007 11:33 AM
pimpyellowtt
06-03-2004 10:00 AM
MHLTT
08-15-2003 05:03 PM
NeverEnough
12
08-06-2003 07:25 PM
