I found a displaced plug while attempted to bleed the clutch. Any advice?
AudiWorld Expert
The plug was about 6 inches toward the passenger side from the clutch bleed nipple. Laying on its side. I cleaned and replaced it, but now I'm wondering what the hell it was covering, and if that's an issue.
The transmission? The hole looked clean. I didn't see any evidence of fluid sloshing around.
The plug has a raised loop as a grip. The hole it plugs is about 3/4" in diameter.
Any suggestions? Replace and forget?
Replace the transmission fluid just to be sure? Redline MT-90?
Something else entirely?
Oh, and what are you guys removing to get better access to the clutch bleed nipple? I gave up. I do not have elfin hands.
Thanks
Thanks
That plug is always falling out..>
Just an inspection port to locate TDC...Better not be any fluid in there! (clutch). Stick it back in (or not)
MT-90 is good...
Skip the Nip...Don't aggravate what could be a costly problem...:-)
MT-90 is good...
90QuattroKid
03-14-2008 07:25 AM
HugeTTs
04-09-2006 09:10 AM
VR_Life
Audi Original "S" Cars
05-05-2005 01:47 PM
Dr. Back Crackin S4
10-22-2003 05:06 AM
