I have a question...would H&R 15mm spacers work
on my OEM "18 RS4 9-spoke wheels('05 3.2 TT)....heard about issues with beveled edges...and things about it only fitting OEM wheels vs. aftermarket wheels. Please help me
AND, would any of you have any pics of a TT with 15mm spacers at the BACK....THANKS
Related question: How does pushing the wheels out affect the handling?
I've got 17x7's with ET35 running 225's and it looks like I could use 15-20mm of spacer in the back and 10-15 in the front to push the wheels out. How does this increase in track and scrub radius affect the handling?
Former Vendor
Couple things
Wider track helps with stability, but also increases scrub radius. Higher scrub radius makes steering response a little harder, and gives a bit more feedback.
Your roll center will also change slightly due to the wider contact path. On the TT chassis it may go up or down, depending on your ride height, and position of the lower control arms relative to the ground.
The change in roll center will be fairly minimal in any case.
Sprocket73
RS4 (B7 Platform) Discussion
26
09-14-2007 07:36 AM
dougie
Wheels & Tires Discussion
08-17-2005 08:47 AM
a4spinner
08-04-2004 09:28 AM
