I want to learn about Audi's implementation of Variable Valve Timing in the 1.8T. Any links?
I was following me Jetta yesterday in my TT and simply could not keep up. Ali powered onto an on ramp and I couldn't catch her.
The only differences between the AWP engine in my Jetta and whatver my TT has is VVT. Different gearings in the tranny can affect it of course, but I know where the power is in my TT.
The good news is that the TT got through the lease-end inspection this morning unscathed and I will receive my deposit back in full. Like, Duh.
There were a number of posts on the VVT on the 1.8T forum in Vortex and the
conclusion is that it really only works during startup for emissions purposes and helps with initial low end torque - but does very little for overall performance. The biggest difference in the ATC and AWP engine is the turbo and compression ratio. Turbo in the AWP is a k03/k04 hybrid and the compression is slightly lower although not as low as the 225TT. The gearing is also significantly different with the TT having much lower gearing in 1-4.
My Audi dealer friend said that in AoA parts class they learned about VVT and he recalls
that is gives more low end and high end torque with the turbo picking up torque chores in the middle of the RPM range. I was hoping to flesh out this explanation since as I understand Toyota and Hondas VVT it only gives more torque high up.
Are we sure about VVT in the 1.8T?
I don't find any references to 1.8T VVT on the Audi site. Neither the TT nor the A4 engine spec includes mention of variable valve timing.
They do, however, note having VVT on the V6 and V8 engines.
This is not to say that it doesn't exist, but I'm curious as to how VVT would be "added" to the 1.8T. Seems like adding such a system is not insignificant... as I understand it, you vary the cam timing by changing the timing belt geometry -- thru idler positioning? That sounds pretty tricky, especially as an 'add-on.'
I figure I must be missing something -- can someone explain VVT and the 1.8T?
Only on when engine cold & never at WOT, in new VWs.
People on VWVortex have sent me their logs, done strictly for emissions. Default position is power position. When cam advance on it gives early intake valve opening letting exhaust gas to travel up intake port then back down intake port, removing fuel film on intake valve head and some off port wall. Early closure increases volumetric efficiency at low to moderate speeds but ECU will switch back to power position so you can't see this the way the have it programmed on the new VWs.<ul><li><a href="http://forums.vwvortex.com/zerothread?id=279826">VWVortex link</a></li></ul>
im_cecil
07-20-2007 10:54 AM
wnut
05-29-2002 12:17 PM
amiro
11-12-2001 10:54 PM
gtt
09-28-2000 03:11 AM
Shoe
02-27-2000 09:44 PM
