Installing rear sway bar.
Having a hard time getting the two nuts off of each side near the wheels
Are the rubber pieces that connect the small arm to the sway bar on each side prone to damage? I'm afraid of tearing the rubber piece with the wrench.
Thanks
Thanks
Rubber pieces..>>
Keep Dirt out of the spherical joints. a 14 or 15mm (sorry it's fuzzy) wrench between the covers and the bar will keep the joint from rotating as you loosen the outside nut.
It might be, but iirc, a 17 fits in there nice and snug. Plus I only have 1 of each, so I usually
use the correct wrench for a main, and something good enough that will hold for counter in case I don't have both wrenches. Try a 5/8" and 11/16" also if you don't have any more metric.
Okay, so what are my odds of totally screwing up this install?
The 4 bolts that hold the bushing guards are not lining back up, and the two screws on each arm (end) don't seem to be lining up straight either.
