Interesting Note
Interesting Note
Here's something very important you must know about your vehicle. The high-performance RS 6 requires special synthetic engine oil, which must conform to Volkswagen Oil Standard 505 01 (5W-40 Synthetic Motor Oil). Failure to use engine oil for your engine that expressly conforms to Volkswagen Oil Standard 505 01 (5W-40 Synthetic Motor Oil) can cause engine failure on the highway that can cause a crash and serious personal injury. Please note the following:
- Never use any amount of engine oil in the engine that does not conform to Volkswagen Oil Standard 505 01 (5W-40 Synthetic Motor Oil).
- Always carry with you an extra quart of engine oil that conforms to Volkswagen Oil Standard 505 01 (5W-40 Synthetic Motor Oil) in case you must top off the oil while on the road.
Never use any other kind of engine oil in your vehicle, not even to top off the oil level. We have provided you with a quart of the approved oil in the luggage compartment.
- If you use engine oil that does not expressly conform to Volkswagen Oil Standard 505 01 (5W-40 Synthetic Motor Oil), very serious and very expensive damage to your vehicle's engine will occur. Your Limited New Vehicle Warranty will not cover engine damage caused by using the wrong engine oil.
- Not all commercially available oils conform to this very rigid Volkswagen oil quality standard, even though they may have the same viscosity.
Your authorized dealer has the most up-to-date technical information regarding the correct oil specification and viscosity or your engine. Always ask your Service Consultant about the correct oil to use when topping off your engine. Refer to your Owner's Manual for details about oil specifications.
Here's a list of European 505.01 oils:
Someone else put this together, lost the name.
AD Parts AD SDI SAE 5W-40 50000/50500/50501
Addinol Addinol Light MV 0546 PD SAE 5W-40 50000/50500/50501
Agip Agip 7004 SAE 5W-40 50000/50500/50501
Aral Aral Tronic 431 SAE 5W-40 50000/50500/50501
Avia Avia Turbo CFE PD SAE 5W-40 50000/50500/50501
Bucher AG Motorex Profile V-XL SAE 5W-40 50000/50500/50501
Castrol Castrol 505 01 SAE 5W-40 50000/50500/50501
Castrol Castrol GTD 505 01 SAE 5W-40 50000/50500/50501
Cepsa Cepsa Star TDI synt SAE 5W-40 50000/50500/50501
Chevron Havoline 505.01 SAE 5W-40 50000/50500/50501
Conqord ROLOIL 505.01 SAE 5W-40 50000/50500/50501
DEA DEA Ultec Diesel SYN SAE 5W-40 50000/50500/50501
DEA DEA Viscobil ST SAE 5W-40 50000/50500/50501
Delek Israel Delkol IDI SAE 5W-40 50000/50500/50501
Denicol Motor Oils Denicol Pro Syn 4 SAE 5W-40 50000/50500/50501
Elf Elf Excellium DID SAE 5W-40 50000/50500/50501
Esso Esso 505 01 SAE 5W-40 50000/50500/50501
Eurolub (Hunold) Eurolub Synt PDI SAE 5W-40 50000/50500/50501
FL Italia Pulsar Progress SAE 5W-40 50000/50500/50501
FL Italia Selenia Performer SAE 5W-40 50000/50500/50501
Fuchs Fuchs Motorenoel G052 167 02 SAE 5W-40 50000/50500/50501
Fuchs Labo Syntha High Tech Synthese SAE 5W-40 50000/50500/50501
Fuchs Motorenoel G 052 167 02 SAE 5W-40 50000/50500/50501
Fuchs Titan Supersyn SL-F SAE 5W-40 50000/50500/50501
Ginouves York 742 SAE 5W-40 50000/50500/50501
Hunold Hunold Synt PDI SAE 5W-40 50000/50500/50501
Igol Igol Process 505.01 SAE 5W-40 50000/50500/50501
Kuttenkeuler Sorotec Pdi SAE 5W-40 50000/50500/50501
Kuwait Petroleum Q8 Motoroil 505.01 SAE 5W-40 50000/50500/50501
Liqui Moly Liqui Moly Diesel High Tech SAE 5W-40 50000/50500/50501
Meguin megol Motorenoel Super Leichtlauf Technology SAE 5W-40 50000/50500/50501
Millers Oils Millers XFE-PD SAE 5W-40 50000/50500/50501
Mobil Mobil Syst S Special V SAE 5W-40 50000/50500/50501
Mobil Mobil TD SAE 5W-40 50000/50500/50501
Molyslide Molyslide Formula L2 SAE 5W-40 50000/50500/50501
Motul Motul 6100 SAE 5W-40 50000/50500/50501
Oest Mineralölwerk Oest Leichtlauföl 505.01 SAE 5W-40 50000/50500/50501
PAZ Champion Oil 50501 SAE 5W-40 50000/50500/50501
Pentosin Pentosynth 5W-40 TS* SAE 5W-40 50000/50500/50501
Petrogal Galp Formula 505 Extra SAE 5W-40 50000/50500/50501
Ravensberger Schmierstoffvertrieb Ravenol VPD SAE 5W-40 50000/50500/50501
Repsol Repsol Elite 505.01 TDI SAE 5W-40 50000/50500/50501
Rowe Rowe Synth PD SAE 5W-40 50000/50500/50501
Shell Shell 505.01 SAE 5W-40 50000/50500/50501
Slovnaft Madit 505 01 SAE 5W-40 50000/50500/50501
Sonol Sonol Synt 505.01 SAE 5W-40 50000/50500/50501
Statoil Statoil Superway SAE 5W-40 50000/50500/50501
Sun Oil Sunoco Ultra semi synth. SAE 5W-40 50000/50500/50501
Suomen Petrooli OY Teboil Diamond SAE 5W-40 50000/50500/50501
SWD swd Primus Synth. SAE 5W-40 50000/50500/50501
Tamoil Sint Future Extra SAE 5W-40 50000/50500/50501
TD Lubrifiants AVIA TDi 505.01 SAE 5W-40 50000/50500/50501
Teboil Teboil Diamond Diesel SAE 5W-40 50000/50500/50501
Total Total Quartz 505.01 SAE 5W-40 50000/50500/50501
Unil Opal Unil Opal Opaljet 505.01 SAE 5W-40 50000/50500/50501
Valvoline Diesel Turbo motot oil SAE 5W-40 50000/50500/50501
Valvoline High Performance Diesel motor oil SAE 5W-40 50000/50500/50501
Valvoline Valvoline Diesel Turbo Motor Oil SAE 5W-40 50000/50500/50501
Valvoline Valvoline High Performance Diesel Motor Oil SAE 5W-40 50000/50500/50501
Vaps Vapsoil PD 540 Spezial SAE 5W-40 50000/50500/50501
Veedol Veedol 505 01 SAE 5W-40 50000/50500/50501
Westfalen AG Westfalen Megatron SAE 5W-40 50000/50500/50501
Wolf Wolf Masterlube Synflow PI SAE 5W-40 50000/50500/50501
Würth Würth Triathlon Special PD SAE 5W-40 50000/50500/50501
Yacco Yacco Spéciale SAE 5W-40 50000/50500/50501
Yacco Yacco VX 505 Diesel SAE 5W-40 50000/50500/50501
Zeller+Gmelin Divinol Syntholight 505.01 SAE 5W-40 50000/50500/50501
minnesotaaudifan
Audi 100 / A6 (C4 Platform)
07-28-2002 08:41 AM
TommyC
12-24-2001 10:56 AM
