Interior Light Problem
Old Sep 14, 2000 | 08:27 AM
spurn's Avatar
Default Interior Light Problem
I have a 225TTR and occassionally (not always) the interior light stays on even if it's on/off switch is in the middle position and all the doors are closed (when it should dim and go off). When this is going on I have to put the switch in the "off" position to turn the light off, even if the doors are closed. Anyone have a similar problem or know what might be causing it? A fuse perhaps?<p>"Nunc est Bibendum"
Old Sep 14, 2000 | 08:39 AM
fredfromny's Avatar
I think that this is the same problem that Brad Willis has
Old Sep 14, 2000 | 09:31 AM
Lloyd of the Rings's Avatar
Default It's a ground problem. The solution is....
to get your dealer to resolve the grounding issue.
A quick fix is to ensure you have closed the doors BEFORE you turn on the ignition...and don't lock the doors until AFTER you have turned the ignition on.
Old Sep 14, 2000 | 09:36 AM
mowog's Avatar
Default mine does it also- last time I played around and noticed the power door locks
didn't function also. Locking and unlocking the car by the remote seems to reset mine. I called AUDI and they have no reports, so call and complain. I figure taking to dealer is waste of time as problem is so infrequent. Total of 4 times in 2 months.
Old Sep 14, 2000 | 09:37 AM
NexxTT's Avatar
Senior Member
Glad you had the patience to figure this out Chris. Thanks.:-)
Old Sep 14, 2000 | 09:52 AM
Had the problem on my old 180.
Old Sep 14, 2000 | 08:59 PM
PorTTland's Avatar
Member
Default TT doesn't like you to open passenger door with the engine running . . .
I have found that if I shut the engine off before letting a passenger in that the light problem does not occur. Someone posted a month ago that this could be fixed by an ECU chip update by the Audi dealer.<p><img src="http://pictureposter.audiworld.com/AudiWorldPics/2000/PorTTlandSig.jpg">
Craig, Nimbus TTRQ225
red90q
Apr 23, 2004 01:52 PM
hoTTub
Dec 27, 2001 10:59 AM
alibaba
Audi allroad
Oct 11, 2001 06:35 AM
Z28Quetzal
Sep 22, 2001 07:36 PM
EdTT
Dec 16, 2000 06:04 AM
