ITALSKIER: Glove box Disassembly Photos
<b> Basic Tools Needed (T25 Torx)</b>
<img src="http://www.rpi.edu/~onksej/Audi%20Stuff/Glovebox/gb1.JPG">
<b> Your Glove box </b>
<img src="http://www.rpi.edu/~onksej/Audi%20Stuff/Glovebox/gb2.JPG">
<b>Remove These First - Side 1 </b>
<img src="http://www.rpi.edu/~onksej/Audi%20Stuff/Glovebox/gb3.JPG">
<b> Side 2 </b>
<img src="http://www.rpi.edu/~onksej/Audi%20Stuff/Glovebox/gb4.JPG">
<b> Remove the hinge pins next: Get them started with screw driver then use the pliers to pull them out </b>
<img src="http://www.rpi.edu/~onksej/Audi%20Stuff/Glovebox/gb5.JPG">
<b> After Separating the two halves - Remove the 8 T25 bolts </b>
<img src="http://www.rpi.edu/~onksej/Audi%20Stuff/Glovebox/gb6.JPG">
<b>Separate the two pieces </b>
<img src="http://www.rpi.edu/~onksej/Audi%20Stuff/Glovebox/gb7.JPG">
<b>These are the two screws which hold the Quattro emblem on</b>
<img src="http://www.rpi.edu/~onksej/Audi%20Stuff/Glovebox/gb8.JPG">
<b> Remove them :-) </b>
<img src="http://www.rpi.edu/~onksej/Audi%20Stuff/Glovebox/gb9.JPG">
<b>If you have any questions buddy let me know. Hope this helps. Also, if you had a small enough T25 bit you could just remove the 8 bolts and the two halfs should also come apart.</b>
<b> Side 2 </b>
post hijack....stilljester, can you comment on what i need 2 do 2 install this part?
<center><img src="http://pictureposter.audiworld.com/21765/glove_box_emblem.jpg"></center><p>
TIA! This has been sitting on my desk for 3 months and needs to get installed! I think for starters I need to buy a small Torx screw driver.
P.S. Bought this at VAG Parts in the UK in case anyone wants to get one. I think it was $55 + shipping.<ul><li><a href="http://www.vagparts.com/index.htm">http://www.vagparts.com/index.htm</a</li></ul>
Sure - Do you have a small T25 Torx driver? If so remove the 8 screws inside and seperate
the glove box face from the inside. The part you need to remove is held in with two flat head screws. Check out the pictures above and if you have any questions just post away, I'll do my best to answer them :-)
HIS4
01-20-2008 08:10 PM
20valvevermont
01-13-2003 12:22 PM
coasTTal
05-01-2002 04:50 PM
