I've now called 6 places, no 3/16 in copper T fittings ANYWHERE!
smallest anyone has is 1/4.
Will that work for splicing the vaccuum line to install the boost gauge.
No one, not compressor supply stores, plumbing specialty stores, Home depot, Lowes, etc... nobody's got these things.
Brass is more commonly available....>
You can get em here: They generally get stuff to you in 2-3 days.<ul><li><a href="http://www.mcmaster.com">http://www.mcmaster.com</a</li></ul>
Then the T I posted above will not work. That is only for use with the real thin nylon hose.
The thin hose is so much easier to run back into the cabin.<ul><li><a href="http://www.ttstuff.com/Merchant2/merchant.mv?Screen=PROD&Product_Code=VDO-150851">Nylon Hose.</a></li></ul>
