Just got a Oil Pressure light with "Min" next to it on the cluster......What exacty....
No need to be a *****, is there? Anyways, some pointers:
Check your oil level. How often do you change the oil? If the oil is not low, you need to pull your oil pan and check for sludge. Good chance your pickup is clogged. I would NOT drive the car or let it run until you have this issue fixed.
