Looking into ModShack Stg 2 and have some quetions:
I have searched and there are quite a few good testimonials. What I am wondering about are what possibles issues I may have with this setup. I don't have a diagnostic tool to clear any codes. Can I expect: Lean/rich codes, boost loss, timing retard, limp? I just want to be ready... Also, for those that say that the boost comes in a lot smoother, is the boost pressure the same as before, or does it not hold as high? I would love to hear some feed back from those that had it for few weeks or longer as well. Thank you all!
if everything else is working properly, you shouldn't have any problems...
you can increase your boost pressure and the boost machine takes out the spikes, which aren't good for power anyway. i noticed a big difference, and I'm running a stock ecu.
I've had V1 and V2 of the BAMM for a ton of mileage..... 30k or more - no issue
whatsoever..... no codes, nada. I don't VAG my car but it's running super nice..... unless you're running on gear that has limited time left on it, you'll be ok! Get yourself a upgraded DV though if you don't have one already!
The BAMM or **** helps removes the initial spike...>>
The BM on the 180 doesn't need the creep valve and much as the 225 due to the size of the K03.
Installing the 4bar will put more gas into the mix but with the BAMM, it should equalize out. I'm running around -.6 idle and -4.6 on partial throttle using block 032.
No problems with **** V2 for the 180. Lots of 225er have reported the same.
Hope this helps.
Hope this helps.
Alias Unknown
Canadian Discussion
10
01-20-2006 09:01 PM
Italo Metto
01-22-2003 10:45 AM
raveman7
12-11-2002 12:38 PM
