maaliish...ygm, pics of boost leak tester cap.
Some advice..
If you install the cap before the turbo you should never push in more than 0,5bar. It can happen that you push out the seals of your turbo and flood it with oil. It's much better to test for leaks starting after the turbo.
I would love to get in after the turbo, but that sounds like a nightmare. I'll first try with 5 psi
after the MAF and see if I can hear the leak. 5psi is just under .5 bar so I should be ok.
Thanks
Thanks
99.5SilverAudiA4
05-12-2007 01:16 AM
Jargen
10-16-2006 11:43 AM
