Measured Block 32 showed 2 readings
your adaptation is way up! >>>
not sure what your car's setup is, but the MAF appears to be gone...
Additionally...if i recall, you are 180....22psi is a little high on boost for the k03. 21psi is really the max you should run....if you have a boost machine, turn it down, and replace the MAF...
If it's old, cleaning probably won't help....>
As Han's pointed out, your adaptation numbers are whacked. Comfortable boost for a 180 should not exceed 20psi....Just a bunch of heat and timing pull beyond that...
I read that as "Old"...Missed it.......Forget the cleaning...>
TURN DOWN THE BOOST, do a throttle body adaptation, drive 20 miles and re-sample the block 32..
The first number is idle correction, and I've never seen one that rich. Anything else change? Type of Air filter?
