more strut removal questions -- what socket to use >>
<img src="http://www.toolfetch.com/media/41372.jpg">
no autoparts stores in my area carried a deep socket 21mm with grooves for grabbing it with a wrench.
can someone give me an idea of what i need and where to get it to make this....
<img src="http://www.purems.com/images/fullsize/mkiv-1.jpg">
i have the following:
- 1/4" ratchet
- 6" ext.
- 1.4" 11mm socket
i need:
- 21mm deep socket with grooves for attaching a crows foot (so i can properly torque)
thanks.<ul><li><a href="http://www.purems.com/products/page.php?pageKey=23">http://www.purems.com/products/page.php?pageKey=23</a</li></ul>
- 1/4" ratchet
- 6" ext.
- 1.4" 11mm socket
i need:
go to a parts store like AutoZone/Discount Auto and look for an O2 sensor socket
that should fit fine..if not, buy a 21mm and grind the sides flat so that the crow's foot will fit.
I used a cheap 21mm socket from Auto Zone
and just locked vise grips around it. It held fine for me to turn it with the vise grips. I think the grips held better because they were locked around the engraved writing on the outside of the socket. If it's smooth, it may not hold very well.
Re: more strut removal questions -- what socket to use >>
<center><img src="http://130.74.81.102/aw/tools/IMG_6627.jpg"></center><p>
I have this gizmo in the picture back from the very early days - changing strut bushings and bearings was the first thing i did. It is metalnerd part MN2122 socket; I also had a shop to weld a 1/2 drive socket to the handle so that a torque wrech can be used. It worked perfecty. I since got a Hazet suspension set T10001 so I no longer need this. You are welcome to it - let me know.<ul><li><a href="http://www.metalnerd.com/cat05.htm">metal nerd socket on their site</a></li></ul>
