need help
its 01 225 and i have to crank it a couple of times to get it to start, i vag commed it and i got a code for the ecm power supply relay.
once it starts it'll start for te next 10 minutes and then it'll have to be cranked a couple times to start.
i took a relay from a mk4 (same part number) and it did the same thing but i didnt clear the code before changing the relay.
is clearing the code part of changing the relay?
my friend had the same problem with his mk4 and said his ecu was fried, would that cause it not to start up some times.
