Need Help to Decipher Engine Fault Codes
Old Jul 24, 2004 | 02:04 PM
Audifan8's Avatar
New Member
Default Need Help to Decipher Engine Fault Codes
Can anyone please help me to decipher the following engine fault codes from a diagnosis report? What has caused the engine to break down? Are there any codes in the attached list that may suggest that the engine is over revved? Thanks very much.
02 -Interrogate fault memory:
11 Fault detected
17963 P1555 035
value above maximum charge pressure
16487 P0103 035
Mass or Volume Air Flow Circuit.
High Input
16712 P0328 035
Knock Sensor 1-G61 Circuit
High
16496 P0112 035
Intake Air Temperature Sensor 1 Circuit
Low
17953 P1545 035
Throttle valve control system
malfunction
17953 P1545 035
malfunction
17987 P1579 035
Throttle Valve Control Module - J338-
Adaption not initiated
17925 P1517 035
Main relay =>-J271
electrical fault in circuit
18010 P1602 035
Voltage supply - terminal 30
Voltage too low
17645 P1237 035
Cylinder 1 injector - N30
open circuit
17695 P1287 035
Turbocharger divert air valve - N249
open circuit
Old Jul 24, 2004 | 03:45 PM
AxeYrCat's Avatar
Member
Default You need a new MAF, something is unplugged or not grounded, the battery was disconnected or died...
That's a LOT going on.
As for the last two codes, it sounds like you either have a bad ground somewhere or that something on the top of your engine (if you have a 225) is unplugged.
Your throttle body is also upset, and if it's under warranty, I'd look into having it replaced or repaired.
Note: this is not especially expert advice, but I had similar problems, and that's what worked for me.
jjyerro
Mar 28, 2016 08:43 AM
bodhi
Apr 4, 2006 09:21 PM
dibster
VAG-COM Discussion
Sep 15, 2005 03:01 PM
JJCNSX
Feb 3, 2005 06:30 AM
Audifan8
Jul 27, 2004 07:00 AM
