Need mod assistance with Hella Horns...
The connectors are different from the OEM and the aftermarket. Do I cut the connector wire from the car? Or am I missing something? Thanks. Joe.
<img src="http://pictureposter.audiworld.com/48863/picture_122.jpg">
<img src="http://pictureposter.audiworld.com/48863/picture_123.jpg">
<img src="http://pictureposter.audiworld.com/48863/picture_124.jpg">
Easy to do...Cut the old connector off that went to OEM horns..connect the two wires to the HEllA
Horns doesnt matter which goes where. I got some adaptors at the auto store and crimp them onto the wires to connect to the Hella Horns and works fine. You might want to get some extra wire depending on where you want to mount them
you can...or you can take the end apart. There are only two leads>>>
i cut mine and regret it. Not that i have had problems...but a cut wire has the potential to be more trouble than a non-cut wire...IMO
Here you go about the wiring..I have a 2002 and order the bracket peice that comes on models
<center><img src="http://pictureposter.audiworld.com/70355/picture_162.jpg"></center><p>
2004 and above that will mount on the center brace. No regrets here on cutting..I cut back enough so if wanting to rewire I could
ModifiedA4
09-19-2007 04:37 PM
Imolsify
32
03-19-2003 03:14 PM
nosey
01-04-2001 04:48 PM
