Need new rotors on the TT. Minimal to no track time planned for it. Plain or Slotted?
AudiWorld Expert
"Slotted, drilled or dimpled rotors should not be considered appropriate for high-speed track use"
Slotted, drilled or dimpled rotors offered as OEM replacements should not be considered appropriate for high-speed track use.
While grooved, drilled and slotted rotors offer an enhanced appearance and add some resistance to the boundary layer of gasses that can build up between the pad and rotor, they are not designed to withstand the extreme temperatures that are produced on the racetrack. If they are used on the track, it is very important that the rotors be carefully inspected and should not be driven on if even minor signs of deterioration are seen. Note, too, that if these products are used on the track they are not warrantable.<ul><li><a href="http://www.tirerack.com/a.jsp?a=AR4&url=%2Fbrakes%2Ftech%2Ftechpage.jsp%3F techid%3D87">http://www.tirerack.com/brakes/tech/techpage.jsp?techid=87</a></li></ul>
You know it's funny people say that. But have you noticed that ALL race cars...>>
seem to have either drilled or slotted rotors.
I do know that with the drilled/slot rotors that I have owned, it DOES make a big difference in rain.
Juat a thought.
Juat a thought.
malone
Brakes Discussion
13
07-10-2007 08:53 AM
Zsr31
24
10-10-2001 03:04 AM
