New TT owner
Hey everyone, new member here. I just registered a 2000 Audi TT Quattro on Wednesday, that I bought for just $500 from a friend who was the original owner. He's put a lot of money into it over the years, including a new engine about 20,000 miles ago. It's certainly a steal, but it does have a few issues. Perhaps some are related, perhaps not. Here are some of the problems.
1) The "ABS "light is on, and the "brake" light flashes. I does not need brake fluid, and the brake pads are fine. It seems to stop fine. The ABS fuse is fine. 2) The "check engine is on. I own an OBD2 scanner, and got just one code: P1136. 3) It takes about 4 or 5 attempts to start. I try, it cranks, I stop and repeat the process. After it's running, it's fine. If I stop in a store or friend's house, it will start right up next time. But if I wait several hours between starts, it'll take the 4 or 5 tries again. This has nothing to do with the weather. Same thing happens whether it's 60 or 30 outside. The fuel pump was replaced by the previous owner, but it did not fix the problem. He doesn't know if they replaced the fuel filter, but I'd imagine they had to. Could it be fuel injectors? MAF Sensor? 4) The glove box light only works when the headlights are on. Is this normal? Either way, it's a minor problem compared to the rest. |
New TT owner here also (2001 Quattro convertible) - welcome to the community.
Unfortunately, I can't offer much assistance with your specific issues - hoping someone will offer you some guidance - but just wanted to extend the welcome. |
Originally Posted by Zap!
(Post 25258163)
1) The "ABS "light is on, and the "brake" light flashes. I does not need brake fluid, and the brake pads are fine. It seems to stop fine. The ABS fuse is fine. 2) The "check engine is on. I own an OBD2 scanner, and got just one code: P1136. 3) It takes about 4 or 5 attempts to start. I try, it cranks, I stop and repeat the process. After it's running, it's fine. If I stop in a store or friend's house, it will start right up next time. But if I wait several hours between starts, it'll take the 4 or 5 tries again. This has nothing to do with the weather. Same thing happens whether it's 60 or 30 outside. The fuel pump was replaced by the previous owner, but it did not fix the problem. He doesn't know if they replaced the fuel filter, but I'd imagine they had to. Could it be fuel injectors? MAF Sensor? 4) The glove box light only works when the headlights are on. Is this normal? Either way, it's a minor problem compared to the rest. Look up your code on Google (Audi service manual preferred) and repair as required. I'd say buy the service manual and Ross Tech diagnostic interface right away to help you. This is a good read. While geared toward the D3 A8, most of applies to your vehicle as well. https://www.audiworld.com/forums/a8-...-read-2877219/ Finally, I recall that early TT's did not have a glove box light switch so the headlights on turning on the glove box may indeed be normal. My Gen 1 VW Scirocco worked in a similar manner. |
Originally Posted by Mister Bally
(Post 25258589)
Generic scanners do not show VW/Audi specific system diagnostics. Best to invest in the Ross-Tech diagnostic interface. You will need it for ABS diagnostics. It sounds like you have a defective temperature sensor that is not "enriching" the fuel system when cranking a cold engine. Again, the proper diagnostic software & interface is paramount.
Look up your code on Google (Audi service manual preferred) and repair as required. I'd say buy the service manual and Ross Tech diagnostic interface right away to help you. This is a good read. While geared toward the D3 A8, most of applies to your vehicle as well. https://www.audiworld.com/forums/a8-...-read-2877219/ Finally, I recall that early TT's did not have a glove box light switch so the headlights on turning on the glove box may indeed be normal. My Gen 1 VW Scirocco worked in a similar manner. As for the scanner, I didn't know about the Audi specific ones, thanks. Do you happen to have a link for one that you recommend? I prefer it to not be all that expensive, but will spend if absolutely necessary. |
Update: Ordered an ANCEL VD500 scanner, which is coming tomorrow, and a temperature sensor. I'll put it in on my day off (Saturday). I also changed the cabin filter this morning. Can't wait to have these problems resolved. :)
I'm sure the Ancel will do the job, but the Ross-Tech provides a whole other level of information.
Ross-Tech: Products |
So the VD500 scanner came today. I finally got to check the ADS and got the following three codes:
00283: Front left ABS wheel speed sensor (G47) 00287: ABS wheel speed sensor: rear right (G44) 01276: ABS hydraulic pump (V64) In other error codes, I also get: 17544: Fuel trim: bank 1 (add): system too lean: P1136 Now I'm no expert, but that last ABS code sounds major. Any idea what the "system too lean" code could be? |
Check out this link on the Ross-Tech site:
17544/P1136/004406 - Ross-Tech Wiki and this: Fuel Trim Info - Ross-Tech Wiki |
Originally Posted by Walpole5
(Post 25260261)
(Post 25258589)
I also changed the MAF sensor yesterday and cleared the code. So far it appears to be riding better. The code hasn't come back just yet, but I have only driven it like 6 miles since the install. Next step is a Bluetooth radio and then the ABS problems! |
