Is this normal?....gap in front axle boot.....
Old 08-18-2006, 11:06 AM
thwyld1's Avatar
Default Is this normal?....gap in front axle boot.....
<center><img src="http://pictureposter.audiworld.com/16205/img_2609.jpg"></center><p>
I was putting new brakes on my TT today and noticed that on the driver's side front axle, the boot appears separated. It doesn't look torn, I just can't believe that it would be open like that. I can clearly see grease inside. My gut just tells me there's something wrong.
Please help.....
Old 08-18-2006, 11:16 AM
Senior Member
XCLR8TT's Avatar
Default That's bad.. you have a ripped boot, they usually give way on the creases
Get it fixed asap. You will also need to carefully inspect the CV joint, if there are rocks or metal chips in there you have likely done significant damage to the joint and will need to replace that as well.
Old 08-18-2006, 11:23 AM
sTTickman's Avatar
Default I just replaced this boot due to a tear. There was like a double lip on that
side that was pretty difficult to slip over the half shaft. Meaning, very tight. The original may have had one of those one time use clamps on it. Regardless, this isn't right. This wasn't a fun repair. I pulled the strut &amp; took off the hub and shaft in one piece. I would guess 2 to 3 hours for a shop. Good luck.
Old 08-18-2006, 11:37 AM
aTTicism's Avatar
No. Replace the boot.
Old 08-18-2006, 07:12 PM
New Member
evil TT's Avatar
Default Re: Is this normal?....gap in front axle boot.....
CV joint boot is gone south but I can clearly see that the suspension arm will also soon to be replaced if you keep using it for supporting the car weight.
Better use the big black donuts under the body. Just an adise
EvilTT
Old 08-20-2006, 06:25 AM
thwyld1's Avatar
Is this the inner or outer boot.....guessing outer......need to know to order a replacement! THX
Old 08-20-2006, 07:43 AM
Senior Member
XCLR8TT's Avatar
Default That is the inner boot. The outer is just behind the rotor.. I don't know the Part #
you might try searching the archive or giving World Impex a call. I think this is the link to the CV Joint assembly, but there isn't enough info to know what all is included.<ul><li><a href="http://www.worldimpex.com/item_detail.html?sku=82798">World Impex CV Joint kit</a></li></ul>
Old 08-20-2006, 08:59 AM
thwyld1's Avatar
Default I'm going for just the boot....inner....$29.16
<ul><li><a href="http://www.worldimpex.com/search_by_model.html?mode=keyword&amp;year=2002&am p;make_id=3&amp;model_id=263&amp;keyword=cv+boot&a mp;x=0&amp;y=0">inner boot at world impex</a></li></ul>
Old 08-20-2006, 11:00 AM
Senior Member
XCLR8TT's Avatar
Default Make sure you wipe out as much of the old grease as possible before regreasing. >>>
When you do, check closely in the grease for any bits of metal or rocks. Depending on how long the boot has been torn, you could have trashed the CV Joint.
Number54
20
11-14-2008 10:10 AM
Shan H
02-01-2008 07:47 PM
rowdyzombie
11-15-2007 09:07 AM
bpjenks
Audi Original "S" Cars
12-11-2002 06:26 AM
Quick Reply: Is this normal?....gap in front axle boot.....
