Not my lucky week :( Ground wire off ECU broke off
You probably remember last week, when the fix of flat exploded in my car, well that was taken care of. I got a really good deal on one of those split second boost controllers and wired it up and everything worked great, until I went to go clean things up and pulled the ground wire(pin 108)out of the ecu connector. I did a ghetto fix by pushing the wire back in and used super glue to keep it in. But how would you fix this? replace the whole harness?
Re: Not my lucky week :( Ground wire off ECU broke off
If you can find the number on the connector, you might be able to special order it from Audi, or find the subcontractor and buy one from them.
thanks, after checking it out a little more, there is a rubber piece that is over the pins. once i pulled that back i was able to see the pin. A little solder and its good as new. My idle was screwed up, but the Throttle adaptation worked like a charm.
tybmw
11-07-2006 02:35 PM
