Not reading engine temp!!!
Old Jul 8, 2013 | 07:01 PM
MonsterTT's Avatar
Default Not reading engine temp!!!
Hello, this may be a bit drawn out but I want to try and find out what's going on. For starters I have a 2001 Audi TT 180 and the dash has been slowly dying off. It started with the temp gauge reading maxed out and the center display shot. I would use the climate control to keep an eye on the engine temp and all was well till yesterday.
I got in the car and was driving around when I saw the climate control said the temp was at 121 deg c. I pulled over and looked under the hood and there was no way this thing is running hot, so off I went to the house and hooked up my Genesis scan tool. As I thought, engine temp right at 190 after a few good pulls. So I did the 49c trick and it was reading -10c and the gauge on the dash now only reads cold and will not move.
Off the that parts store I went to get another temp sensor for further diag and it is still reading the same. My question is where dose the climate control get the temp info from. I don't think it's the ECM as its showing the proper temp on my scan tool. I got a replacement dash pod on order and hope that will fix it but I just want to see what you all think.
Old Jul 30, 2013 | 07:55 PM
bugsTT's Avatar
Where are you getting the new pod from and how much?
Old Aug 1, 2013 | 07:31 AM
jaz50y's Avatar
I had a similar problem and had to replace the thermostat and sensor - about $500. Benefit besides reading temperature correctly is that heat and a/c seem to work better. I had already done the pod a few years ago.
Longwolf (Christian)
Feb 11, 2008 12:42 PM
SparTTan
Sep 29, 2006 12:28 PM
Straz85
Apr 28, 2006 04:51 AM
Tx2
Jan 25, 2001 04:56 PM
