Numerous Acceleration Problems
Old Mar 12, 2020 | 06:15 AM
Paul White's Avatar
Default Numerous Acceleration Problems
Hey guys, looking for some possible resolution to a number of problems I am experiencing with acceleration.
Firstly, car and any mod details;
2002 Audi TT Mk1 8n
103k miles
RAM air intake
APR stage 1 MAP
Decat pipes
Forge splitter valve
manual boost controller
mechanical boost guage
The issue I am having is very irregular acceleration problems, such as;
jerky in the low revs before boost comes on
intermittent boost loss in all gears, no pattern to this
so for example, WOT, the boost will spool up to 1.5bar no problem and the car pulls nice and hard, and then all of a sudden, ill go for full acceleration again and it jerks a load, and then only spools up to 0.5bar.
ive just replaced the MAF, and the N75 valve hoping these two might be the cause, but today when test driving, no change whatsoever.
I am really losing the love for the car now because I cannot figure out what is causing this. Sometimes, it doesn't happen at all and drives perfectly, and then out of nowhere, all these problems start happening.
any advice on my set up, good or bad criticism is very welcome, I just want my nice performing car back
cheers in advance,
paul
Old Mar 12, 2020 | 05:59 PM
Mister Bally's Avatar
Massive air leak between the air intake system and intercooler(s).
Old Mar 13, 2020 | 12:25 AM
Paul White's Avatar
many thanks for the response.
I have a FMIC install on the TT. I cant hear any leaks, and would have thought that if I had a leak, the issue would be present at all times?
Old Mar 13, 2020 | 02:00 AM
Paul White's Avatar
update.
yesterday after I ran VCDS I had no codes (other than O2 sensors as I have decat pipes) but today, all manner of errors;
P0130 N249 VALVE MECHANICAL MALFUNCTION
(get a stock 710p 710n DIVERTER VALVE)
P1555 MAXIMUM BOOST PRESSURE EXCEEDED, INTERMITTENT
P1296 ERROR IN MAPPED COOLING SYSTEM
P1602 POWER SUPPLY B+ TERMINAL VOLTAGE TOO LOW
P0103 MASS AIR FLOW SIGNAL TOO HIGH
P1548 BOOST PRESSURE CONTROL VALVE (N75) OPEN CIRCUIT
01435 - BRAKE PRESSURE SENSOR 1 IMPLAUSIBLE SIGNAL
01314 ENGINE CONTROL MODULE NO COMMUNICATIONS
I have changed out the MAF and N75 so these may not return after I test drive this am but the others....
Old Mar 13, 2020 | 06:46 PM
I'd be looking for a tear in a rubber boot/coupling on the pipes between the turbo, intercooler, air filter and intake manifold.
Old Jun 22, 2020 | 06:18 AM
Paul White's Avatar
just to respond to this, I have opened another chat elsewhere on the site.
I ran a pressure test through the intake and no leaks detected - it held pressure fine.
Still still chasing this PITA issue
Old Jul 10, 2020 | 09:22 PM
Breyden Phillips's Avatar
I agree with bally is sounds like a major boost leak. Mine was doing the same thing right after I installed a FMIC. Does it only do it after hitting full boost or does it do it from the very beginning? I would also tell you to do the N249 delete. It will make your acceleration better (it does for cars that are running right). The N249 will release boost at random times and it may be something to look into.
jjm's quattro
Nov 7, 2019 04:11 PM
Global Autosports
May 9, 2012 12:39 PM
gotpressure??
May 1, 2005 08:41 AM
XcellR8edAudi
Quattro: Turbo / Ur / Sport
Aug 2, 2004 06:18 PM
