Offsets on the new wheels look hot!! Kinda pokey.. need rolling advice!
Old 05-06-2005, 09:14 AM
ePuFFy's Avatar
Default Offsets on the new wheels look hot!! Kinda pokey.. need rolling advice!
Sorry for the dark pics...My wheels are kinda pokey... and on big bumps I'm rubbing/hitting the fender... Can I "roll the flat part on the inside of the fenders" myself?
REAR
<img src="http://i3.photobucket.com/albums/y80/logigeek/IMG_3821.jpg" alt="Image hosted by Photobucket.com">
FRONT
<img src="http://i3.photobucket.com/albums/y80/logigeek/IMG_3817.jpg" alt="Image hosted by Photobucket.com">
<img src="http://i3.photobucket.com/albums/y80/logigeek/IMG_3816.jpg" alt="Image hosted by Photobucket.com">
Old 05-06-2005, 09:21 AM
Elder Member
kodeTT's Avatar
take the top center screw off...should help alittle.
Old 05-06-2005, 09:26 AM
YosemyTT's Avatar
Default Wow! Those pics are
totally worthless :-)
You have to get better pics than those!
Old 05-06-2005, 09:33 AM
dougie's Avatar
how about a side shot?!
Old 05-06-2005, 09:34 AM
Member
boostedTT's Avatar
Poke is the bomb!
Old 05-06-2005, 09:40 AM
GorTT's Avatar
do you ever get out in daylight? :-)
Old 05-06-2005, 09:43 AM
TTear's Avatar
Default Can't tell from these pics but...
It looks like the fronts are marginally past the fender line. Are these the Axis' with the 15mm spacers up front?
Rolling the fenders should solve your problems once and for all. Not a big deal, I would recommend it (it looks like you really need it at the front). Maybe at the rear you could get away with just removing the center screw as kodeTT suggested.
Old 05-06-2005, 09:45 AM
ePuFFy's Avatar
Default thx, did that in the front... helped a little, but still rubbing..
i'll do the rears tonight and see if it helps... the wheels are pretty stuffed in there, fronts are 2MM fron the strut too!
Old 05-06-2005, 09:46 AM
ePuFFy's Avatar
haha... they're coming this weekend!
Old 05-06-2005, 09:47 AM
ePuFFy's Avatar
Default so "rolling" means bending back the material inside the wheel well >>>
just want to make sure i'm using this terminology correctly. Thanks again for all your expert offset/spacer help! The wheels look hot, i'll send you some pics this weekend!
Quick Reply: Offsets on the new wheels look hot!! Kinda pokey.. need rolling advice!
