Oil Catch-Can Question: Can you just splice in a "catch can" using this hose? .........
<img src="http://images14.fotki.com/v256/photos/1/168597/3068524/DSC02321-vi.jpg">
Or do you have to remove that black plastic valve and related hoses?
That's what the regulator does...>>
or is "supposed" to do. Doesn't do a real good job when something upstream (PCV valve) is leaking. Honestly since I changed the way that line vents with my system I haven't caught more than 1/2 teaspoon in the can in a couple of years. I think a lot of it has to do with the way the system vents through that part...
I used the compressor filter and drilled about 8 1/8th holes around the base of the filter that is inside it....
I'm going to experiment a bit. I really didn't like what I found when I ........
installed my FMIC. I'm really curious to see what's getting by that regulator. Thanks.
GBW
03-12-2007 07:29 AM
aerohr
02-13-2006 03:43 PM
