Is oil change easy for TT??
I would like to change oil to my TT. I've done some oil changes to my previous Nissan car and it was easy. Was wondering has anyone done it by themselves? Does it really require dealer's help?
Thanks.
Thanks.
Re: It took "10 minute oil change" 40 min. to change mine.
Skid plate removal is the only time consuming part of the job.. That's probably what screwed up the 10 minute oil change place
20 min job. Do it myself. Filter isn't a pain if you have the right tool. Get an
oil filter wrench. They only cost like $3 at Walmart. And when you replace the filter dip your finger in fresh oil and put oil around the seal of the new filter before installing it. Then only hand tighten it (but tighen it good). If you use the wrech to tighten it only give it a little help.
