OT: DOS programming
Old Jan 18, 2002 | 01:00 PM
Merou's Avatar
Member
Default OT: DOS programming
I'm sure one of you guys knows how to do this... I'm working on a bat file where at one point I have to append a time flag to a file name. So I have to rename "filename.txt" to "filename.txt.Dyyyymmdd.Thhmmss" (I actually have to insert the letters "D" and "T"). How can I do that? Can I do something like:
set variable=variable & "D" & ...?
Also, is there a command that will return ONLY the hour, the minute, etc?
Thanks in advance to all you programming gurus out there
Old Jan 18, 2002 | 01:31 PM
TTom TTR's Avatar
Default Do you mean REAL DOS or Windows Command Line?
If it's windows command line yer ok so far, If it's real DOS that file name won't work at all.
How good are you with command lines? Do you have any other applications hand that would cut off file names?
You'd need to have a batch file that did someting like this:
generate time to a text file (cmd > test.txt)
then ren <filename> < test.txt (*should take contents of text file as rest of text)
There isn't astraight command line tool avail with windows to do this. You'd have to find/make one.
Old Jan 18, 2002 | 01:34 PM
Merou's Avatar
Member
Default Sorry you're right - win cmd line.
Maybe I should just right a small VB program and call it up from the bat...
Thanks for the advice.
stadtjunge
Pacific Northwest Discussion
Apr 15, 2006 12:19 PM
the senator
17
Jan 7, 2004 07:17 AM
truth
Apr 11, 2001 06:57 PM
amiro
Oct 16, 2000 08:42 PM
