TripleBlackTTQ |
07-16-2018 07:54 AM |
P0221 Code Help
OK - so I'm a newbie and not exactly the most technical person but fairly capable with a tool box and not afraid to try and fix something. My 2005 Audi TT Quattro was doing well until I started her up to drive home from work and she threw a few lights on the dash. The EPC light, the CEL, and the Triangle with circle arrow and exclamtion mark - ESP ?? - light. Took it to the local parts store and they scanned it for codes - P0221 showed up. The clerk said I needed a new throttle body - $250 and up - so I limped her home and started trying to research how to fix. Here's where I'm at - dislocated battery, removed and cleaned throttle body (did not take apart the sensor) and reinstalled, hooked up battery, turned ignition to "ON" and let it set for about 4 minutes - then turned off. Then started her up - no lights on dash - idles awful, erratic revs, almost sounds like its trying to backfire. Turned her off. Didn't want to cause further damage. Any suggestions? And Thank you in advance for your help!
