Poll - Failed Fuel Sending Unit(s)
Old 10-15-2004, 01:22 PM
  #21
FasTTr's Avatar
So do we have any lawyers on the forum? $900 every 15K-25K sounds expensive!
Old 10-15-2004, 01:33 PM
  #22
TTurner's Avatar
I think mine might be failing now...haven't had it in dealership yet...40K miles
Old 10-15-2004, 01:37 PM
  #23
msauve's Avatar
Default They corrode, possibly due to oxygenated gas. If you take it out...
you can use a pink pearl eraser to burnish the contacts, and they will be back to normal. I had to do that once, about 30K ago, been fine since. I expect I'll have to do it again at some point.
(corrode, not like getting eaten away, but like develop an insulating oxide film)
Here's a post I made OTOF at the time:
My fuel gauge was reading high - close to 1/2 with over 300 miles on the trip odometer, a natural event on a TDI, but not on a TT.
VAG-Com showed the resistance fluctuating (measuring block 2), so I pulled the fuel pump. Attached to the side is a ceramic circuit board with multiple contacts and resistors across which a set of sliding contacts move with the float. I figured that corroded or contaminated contacts were the problem.
To get to the contacts, you need to remove the metal rod which holds the float. It's a press fit and can be removed by carefully prying with a small screwdriver. After doing so, the plastic piece which holds the moving contacts can be removed easily. The circuit board is on a plastic carrier, after removing it, the circuit board can also be removed.
I then cleaned both with a contact cleaner, then used a "pink pearl" eraser to lightly burnish all points of electrical contact.
Put it back together, and not much change at all. Foo. But, I've got a Quatto, so there's a second sender in the left side of the tank. The two senders are connected in series so the gauge reads the sum of both sides of the tank.
Pulled the secondary fuel pump, and cleaned those contacts, too. That took care of the problem - the gauge now reads about 3/16, where it read 7/16 before.
Much cheaper than a new right side sender (about $80) or a secondary pump (about $135, no separate sender available).
Old 10-15-2004, 01:43 PM
  #24
New Member
sacaudi's Avatar
Both Units (left and right) failed at 50,849 miles
  #25
SparTTan's Avatar
Default 80K, and this is probably the ONLY thing that hasn't failed on my car.
But I probably just jinxed myself.
Old 10-15-2004, 02:16 PM
  #26
TTRicks's Avatar
I know we've got one OTOF. Guilty is a lawyer.
Old 10-15-2004, 02:19 PM
  #27
TTRicks's Avatar
How long did it take you to do all that?
Old 10-15-2004, 02:25 PM
  #28
msauve's Avatar
A couple of hours.
Old 10-15-2004, 03:05 PM
  #29
New Member
xlr8d's Avatar
Currently failed @ 40k, needs to be fixed under 3rd party warranty
Old 10-15-2004, 03:28 PM
  #30
Don
New Member
Don's Avatar
Default The question that we should be asking is...
where in the country are these failures occuring. It could well have to do with the fuel quality - oxygenation and use of alcohol and or methanol.
Quick Reply: Poll - Failed Fuel Sending Unit(s)
