Powdercoated gauge mount installed.
<center><img src="http://pictureposter.audiworld.com/90421/audi_148.jpg"></center><p>I still need to install the oil pressure transducer. I ran the wiring, but it looks like the intake manifold has to come off to install the transducer.
It's not as smooth as I would like, suprisingly it isn't very visible in real life...
I'm probably going to work up a black filler to try to clean it up a bit. My real complaint so far is that the green LED from the Passport button is damn bright when you're driving at night. I need to cover that with something smoked..
Fitting that directwire setup was a bitch. It doesn't have a flat face, so it's flush on both ends and sticks out about 3/4's of the way to the right. So if you look at it from behind, it's tilted at about a 25° angle. It was a tough hole to grind by hand...
Yippers®
10-31-2004 06:41 PM
Niko_F
01-16-2004 06:04 AM
