Power Window Problems
Old Aug 14, 2001 | 09:20 AM
Oidivnikufesin's Avatar
New Member
Default Power Window Problems
My 2000 CQ is having problems with the one-touch up and down on control on the drivers side for the passenger window. The one touch works fine for the driver window, but when I try to lower the passenger side the one touch does not work. The window will go down if I hold the switch down. I already had this replaced about one year ago for the exact same problem. Is there any way to reset this or am I going to have to have it replaced again?
Old Aug 14, 2001 | 10:58 AM
glenl's Avatar
New Member
Default Mine just started this nonsense as well
I have a 2001 225 coupe that seems to have forgotten how to reset on the passenger side. The one-touch feature needed to be reset practically every other time I used it and for the last few days has refused to reset. I'm a little bummed to think this is broken after only 2600 miles...
Old Aug 15, 2001 | 05:53 PM
RobDillon's Avatar
Default Re: Power Window Problems
This seems to be a design problem. A dealer, who failed to fix the problem, explained that the windows have a pinch control mechanism.
This pinch control is sensitive to friction in the window guides. Too much friction and the window thinks that there's an obstruction and so it stops.
I have intermittent loss of control on both windows in a coupe.
sbrar96
Q7 MK 1 Discussion
May 21, 2014 04:18 PM
a4-to-go
Mar 7, 2005 08:10 PM
ToreroTT
12
Apr 17, 2002 02:42 PM
D Sealy
Nov 26, 2001 03:37 PM
Kugs10
Feb 26, 2001 06:18 AM
