problems??
Old Jan 9, 2001 | 07:01 PM
superflyTNT's Avatar
New Member
Default problems??
- about 4 times in my 3 months of ownership, when i start the engine, the ESP warning light on my TTR would stay on and won't go away even when i push the ESP button. it goes away when i restart the engine. has anyone have this problem?
- the other thing is cd player related. recently, happened twice, when i play any cd in random mode, the display that show track number and all that, would show the same track number when the song is clearly the next random song. and the display would show the right track number after 20-30 seconds after the song started. is this a memory thing in the cd or something?
thnx
khai
Old Jan 9, 2001 | 07:11 PM
bradh's Avatar
New Member
Default Re: problems??
Your ESP problem is mentioned briefly in the Owner's Manual on page 101. Probably a malfunction.
Old Jan 9, 2001 | 07:58 PM
RogerL's Avatar
Junior Member
Is the ABS light also on???
Old Jan 9, 2001 | 08:17 PM
KaraTTkid's Avatar
New Member
Default same problem
My TT has the same issue with the ESP. I took it in and they said there was an error that came up on the computer. Something to do with a sway bar or something. I have to take it back in a few weeks to get my instrument cluster swapped out. They'll fix the ESP problem at the same time stating that it wasn't hazardous to drive. Bottom line is you need to take it in. Nothing you can or should try to fix yourself. That's my unprofessional opinion :-)
I don't have a clue about your cd player. Good luck.
zub3qin
Nov 20, 2010 01:09 PM
Subliminal
Mar 31, 2007 02:30 PM
Frost12
Nov 5, 2002 11:08 AM
TTOnOrder
Dec 11, 2000 06:34 AM
phrases37
May 31, 2000 05:42 AM
