Problems with signal lights
Old 10-24-2005, 11:29 AM
Junior Member
SharkyS4's Avatar
Default Problems with signal lights
hello all,
I'm experiencing some weird issues with my signal ligths. My symptoms are erratic blinking pattern, no blinking at all, the lights and green arrow will be on solid. Sometimes there is no signal or green light on the panel at all. I also have my right side parking light out, but the signal light works.
Doing a search, the only two possible causes I found were a faulty instrument panel or a fried fuse #22. The instrument panel seems OK, no gauge issues and the fuse is fine. Could the culprit be the lever switch itself? Is there a relay that could be fried as well?
Before I take it in to the stealer, I'd wanted to run it by the forum...
Thanks,
-SharkTT
'02 ALMS Red
Old 10-24-2005, 11:42 AM
AudiWorld Uber User
TTschwing's Avatar
Default Blinker relay....>
Which is built into the hazard switch in the dash.... Bout a $45 part. Lot of this reported...Pretty common. Search for SparTTan's easy replacement thread..
Old 10-24-2005, 11:51 AM
Junior Member
EvotechTT's Avatar
Damn Schwing, you just know everything....Good 4 u !!! =o)
Old 10-24-2005, 12:10 PM
Junior Member
SharkyS4's Avatar
Default God of the TT, I bow to thee...
Thanks again Steve...
-SharkTT
Old 10-24-2005, 12:12 PM
AudiWorld Uber User
TTschwing's Avatar
Default My brain is spongelike......>
Unfortunately full of holes....:-)
Old 10-24-2005, 12:43 PM
sTTickman's Avatar
Default Crap, I've had 3 go bad so far. I would have thought they would
have updated them by now. Geez! I'm am quite good at replacing them at this point. : )
Old 10-24-2005, 01:02 PM
Elder Member
kodeTT's Avatar
haha. you're going to have to go trick-or-treating as Sponge Steve.
Old 10-24-2005, 03:17 PM
EGRoadster's Avatar
Default 2 of them replaced on mine.
And the signal handle too.
BobbyJim
S4 (B8 Platform) Discussion
02-22-2013 04:49 PM
86graphitecoupegt
11-22-2006 05:45 PM
billb
08-14-2006 08:16 AM
87stuna
05-12-2005 09:59 AM
82audicoupe
06-13-2003 03:13 PM
Quick Reply: Problems with signal lights
