PSS9 V.S KW variant 2 coilovers
WHich one is better between these two coilovers??
Need suggestion , thanks |
I don't believe anyone has ever compared the two . . .
but the PSS9's offer 9 way adjustable dampers, that adjust both compression and rebound. The PSS9's use Bilstein Dampers and springs.
The KW's use Koni dampers but I don't know if they use adjustable dampers. I don't know anything else about the KW's. |
PSS9's use Bilstein Dampers and Gruber springs, the KW Variant II's use Koni's (soon to use Alko)
dampers and i'm not sure who make KW springs. The Variant II's are adjustable - but for rebound dampening only. You also have to unbolt the bottom of the rear shocks on the KW's to adjust.
So, what you mean is PSS9 is better right ?
I have only seen the Variant 1, was not impressed with the quality of the components at all
I cna't comment on the Variant 2. But I plan on getting PSS9's for better control of the setup.
thank you for your opinion , it's helpful. then i think i would go for PSS9's since most ppl use.
See if you can find a store with the V2's and see what they look like
I was just telling you about the Variant 1's I saw.
I don't want to get yelled at by anyone for steering you towards something you might have wanted to get. :) |
