put in fr sway bar bushing...but noticed subframe bolt missing!
Old 05-24-2008, 11:14 AM
Junior Member
rowdyzombie's Avatar
Default put in fr sway bar bushing...but noticed subframe bolt missing!
I had clunking sound from pass side. Replaced shocks, strut bearings (68K miles). Just replaced sway bar bushings with powerflex...then I noticed the big m14 1.5 x 95 mm bolt right there holding the subframe to body was gone!!! Whoever the mechanic was obviously stripped the nut and just didn't say anything to owner.
I guess that could be the cause of my knocking noise. I shined a light up there and didn't really see threads, so I guess I'm screwed. Anyone know how to repair this?
Old 05-24-2008, 11:22 AM
Blue TTop's Avatar
Not sure of the location without a picture, but Helicoil might be worth a try.
Old 05-24-2008, 11:46 AM
Member
ShafTT  (aka CrafTT)'s Avatar
If its the one under where your feet would be than it is a helicoil.
Old 05-24-2008, 11:48 AM
Blue TTop's Avatar
Nice Sig pic. Rich! You going to TT-East?
Old 05-24-2008, 11:52 AM
Member
Default Yup! just registered. I was in Fairbanks about 15 hours ago. I was hoping to get down to anchorage
Now I'm in japan
Old 05-24-2008, 12:31 PM
Blue TTop's Avatar
Default Great! Seeing your sig reminds me of when I was at Maxwell AFB.......
a couple years ago for the Air University. I was able to climb into your "office" while it was on the ground. VERY impressive. Hard to imagine laying down while in flight and that hatch is open. Must be a bit of a rush.
Old 05-24-2008, 05:23 PM
Junior Member
Default It's the front bolt for subframe, #15 in bentley manual
It's the bolt a couple inched in front of the swaybar bushing bolt. I just jacked up car on that side, and sure enough a 1/8 inch gap between subframe mount and body when lifted. Thinking of busting out the epoxy, but hoping better solution.
It says in Bentley this bolt can't be repaired with helicoil...says the whole mounting assembly must be replaced...which is welded onto the body.
Old 05-24-2008, 07:18 PM
Blue TTop's Avatar
That is bad. Epoxy is NOT safe. You need to have that bracket replaced.
dmac
A4 (B7 Platform) Discussion
11-17-2007 01:23 PM
S4ortified
9
01-01-2007 07:04 AM
Oo.et.oO
05-26-2006 12:48 PM
beejohn
06-05-2005 10:13 AM
Killer Bee
05-25-2003 03:11 PM
Quick Reply: put in fr sway bar bushing...but noticed subframe bolt missing!
