Question about headlight unit...
My passenger Xenon headlight unit was damaged in an accident from the previous owner... it's repaired with duct tape and the wiring is going bad.
My question... do I have to replace the unit with another Xenon version, or can I buy a non-Xenon, and replace the bulb with my Xenon components from the other unit. TIA, Vince. |
You can do that. Remove the wiring harness, bulb ignitor and bulb sockets. Requires a Tamper-Torx...
bit, but it's pretty easy to do.
Headlight cases should all be a the same for Xenon and non-xenon. there may be a plug in the non-xenon headlight housing where the Xenon power supply mounts, or you may need to cut a hole, but it should work OK. |
Thanks Jeff!
