Question for suspension experts
I have a friend whose steering wheel vibrates at 65 - 75MPH. Since his tires were worn, he ordered four new tires which of course were balanced and he had them do a front and rear end wheel alignment. After all this, the steering wheel still vibrates. Any thoughts about what could be causing the problem?
Re: Worn wheel bearing, wheel bent or out of round, not balanced very well.....
Johnrg: I'm betting on worn wheel bearing. When I drove his car I heard a low whinning sound coming from his left front tire area. The owner of the car didn't even hear it. In the old days you could look at the bearing but now it's packed in a unit. One thing I didn't know is that a bad bearing could cause a steering wheel vibration.
Check the A6 board, tons of discussion on this over there..
In fact I think a few folks have gone as far as buy backs and swaps for other cars. I'm not sure anyone has really figured out the root cause yet.
Re: Wheels could be out of round
<B>Wheels could be out of round</B>
That would be the first thing you would typically look at but since he has the same vibration with both the old and new tires, I'm thinking it may be something else. Maybe a wheel bearing as Johnrg suggests.
Re: Check the A6 board, tons of discussion on this over there..
JohnLZ7W: I use to race cars and worked on suspensions many years ago and I'm far from an expert, but I can't believe that a root cause of the problem can't be found. If you look at the components, there just aren't that many that can cause your steering wheel to vibrate.
Normally it will get louder and make a rumbling noise.......
I'm just guessing at all the possible causes but your right about it not normally causing that kind of vibration except possibly in a bad case.
