question for you wheel/suspension guys...
Old 04-25-2006, 08:14 AM
Blue TooTh Fan's Avatar
Default question for you wheel/suspension guys...
if I run 8.5 inch wheels with stock suspension but a 20mm spacer, will that be too wide? thanks in advance!
Old 04-25-2006, 08:18 AM
nikhil's Avatar
8.5" wide with what offset?
Old 04-25-2006, 08:42 AM
Member
AxeYrCat's Avatar
Totally depends on the wheel. As mentioned, the ET or offset will determine that.
Old 04-25-2006, 08:58 AM
I am basically looking to see if I can fit these on the TT with 5X112 adaptors.8.5J x 18 ET 20
Old 04-25-2006, 09:21 AM
Russ Scott's Avatar
Default sorry, the thinnest adapter available is 20mm's thick... you'll wind up at et=zero
and "out" past the fenders
Old 04-25-2006, 09:32 AM
aTTicism's Avatar
Default Yes. Offset calculator, front will be 22mm outside fender edge and rear will be 16 mm outside.&
Do search for offset calculator and check it yourself.
It will not work.
Old 04-25-2006, 09:57 AM
darn it! thanks though
thanks..
Old 04-25-2006, 02:13 PM
MaxHedrm's Avatar
Time for a wide body kit! :^D
Old 04-25-2006, 03:43 PM
Member
TTGram's Avatar
Only if offset is less than 40mm.
Yoshimura
12-22-2017 05:21 PM
MiniMan
Audi Original "S" Cars
04-23-2007 12:10 PM
siberian
Wheels & Tires Discussion
10-19-2000 09:08 AM
Frank L.
07-13-1999 03:06 PM
Quick Reply: question for you wheel/suspension guys...
