random/multiple misfire and misfire on different cylinders codes, ASB and ESP lights w/ no codes...
I had a buddy VAG my car last night at one of our Audi club gtgs. I had the misfire codes in the engine control module, so I'm guessing I'm due for a set of coil packs. anything else that would cause these?
Also, my ABS and ESP lights have been coming on, but when he checked the abs module, no codes. any ideas on this one? I would assume an abs sensor is on the way out, but with no codes it makes me wonder.
the ABS/ESP errors could be caused by your misfires as>>>
fuel delivery is changed with the errors....
Or...the MAF signal could be getting bogus readings and setting it off too....
Fix the plug/misfire issue, and the other MAY go away....
More than likely...plugs and coilpacks...but you may want to run some Techron in it first, just to be sure...
AlvaroJ
02-17-2012 05:17 PM
DWP
09-13-2008 05:19 PM
TheSkinFox
18
11-02-2007 06:26 PM
juttin
12-21-2004 12:14 PM
