REALLY NEED SOME FAN HELP.
ill start off simple the car is over heating and the fan isn't turning on. Here's what I've done so far. the FCM, water pump, radiator switch, green cap sensor and thermostat has all been replaced in the last year. I took the #16 fuse out and nothing. Jumped the thermoswitch and low speed comes on but not high. jumped the fan and both high and low worked. Checked all the fuses on the battery and they're all good. swapped out the fcm (with the fuse still out) with the old one(it worked but it kept the a/c comp on and drained the battery so i had to swap it.) and still nothing. I did notice that the top radiator hose is hot while the lower is cooler that goes to the thermostat is colder but i did flush the system before when i replaced it and i can here the fluid moving when i squeeze the either hose so i don't think it's plugged. the temp use to stay around 103 when the fans kick on but now it's hitting 108-109 using the 49c way. I'm seriously at my wits end with this car and my gf loves it so i really want to get it fixed for her but i'm getting tired of the constant fighting with it. any help would be greatly appreciated.
